Configure Port Lock
Configure port lock to administratively lock a port or ports to prevent other users from changing port parameters or modifying port action. You cannot modify a locked port until you unlock the port.
    enable
    configure terminal
  2. Enable port lock globally:
    portlock enable
  3. Log on to GigabitEthernet Interface Configuration mode:
    interface gigabitethernet {sub-port]][,...][slot/all][all]}
  4. Lock a port:
    lock port {sub-port]][,...][slot/all][all]} enable
Switch:1> enable
Switch:1# configure terminal
Switch:1(config)# interface GigabitEthernet 1/1
Unlock port 1/14:
Switch:1(config-if)# no lock port 1/14 enable
The following table defines parameters for the interface gigabitethernet and lock port commands.
Variable
Value
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
For the lock port command, use the no form of this command to unlock a port: no lock port {slot/port[/sub-port][-slot/port[/sub-port]][,...]}
